Drawing Template selection issue
ubi.james13
Message 1 of 8
ubi.james13
I have a Drawing Template for our company which I'm very happy with, the problem is when I want to make a drawing I select drawing from design ,the  drawing dialog box pops up with my template already selected, I then select OK but a box saying can't find file, I then have to select drawing from design again but this time browse for my template in the pop-up, select it, then on OK it will come up with the warning box saying it can't be found then finally on the third try I select drawing from design , my template is pre selected  but this time clicking Ok take me to my template and all is ok from then on until I shut program down but I usually have to do it all again when starting a new session ! Drives me mad !
Replies (7)
Message 2 of 8
nemadec
@ubi.james13
Just as initial steps, Can you try with clearing cache--> Restart Fusion & check if facing the issue.
Chandrashekhar Nemade
Sr. SQA Engineer
Message 3 of 8
ubi.james13
Cleared Cache same problem !
Message 4 of 8
nemadec
Thanks @ubi.james13
Just few question :-
1. Is template which you are using is in same folder, different folder or different project?
2. Will you be able to share the template for which you facing issue?
Sr. SQA Engineer
Message 5 of 8
ubi.james13
1 :-The Template is store in a different Project Folder
2:- https://a360.co/2QsQ2eC pw= letmein
Message 6 of 8
nemadec
@ubi.james13
Can you check link, Not able to access the template.
Sr. SQA Engineer
Message 7 of 8
ubi.james13
@nemadec try this link
https://a360.co/3sI4EUy
Sorry for slow reply just very busy, still having  issue ! sometimes its fine other times it's not
Message 8 of 8
g-andresen
I could select the template from the project folder as well as across projects.
After restarting, it is in the first place after starting the drawing mode.
günther
