Drawing module freeze
hedt_angstrom
hedt_angstrom
Hi.
After adding a sheet to the drawing Fusion 360 becomes frozen. The only thing I can do - close the app.
Repro steps:
1. From the design (hybrid assembly), from object tree select a component and create drawing (add a sheet to an existing drawing).
2. Result: in the drawing document new sheet is added. The object tree contains a component source but it's name is broken. UI is locked. No sheet content is visible.
3. Drawing document becomes broken. When I reopen it the result is the same.
Tried to rollback to older drawing document version but result is the same when open it.
Update:
Tried to export to .PDF from the cloud - the file content is alive.
mohammed.aliTDPXK
Hello @hedt_angstrom ,
I tried the same workflow, but I could not reproduce the issue at my end, can you please share me Drawing file for which you are getting this issue?
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
hedt_angstrom
Absolutely. Please check private messages.
