Drawing module freeze
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi.
After adding a sheet to the drawing Fusion 360 becomes frozen. The only thing I can do - close the app.
Repro steps:
1. From the design (hybrid assembly), from object tree select a component and create drawing (add a sheet to an existing drawing).
2. Result: in the drawing document new sheet is added. The object tree contains a component source but it's name is broken. UI is locked. No sheet content is visible.
3. Drawing document becomes broken. When I reopen it the result is the same.
Tried to rollback to older drawing document version but result is the same when open it.
Update:
Tried to export to .PDF from the cloud - the file content is alive.
