drawing line error
drawing line error
m.podsiadlowicz
Message 1 of 10
drawing line error
m.podsiadlowicz
Hi
When generating a drawing from an object, an error occurred as in the attachment.
A line is missing.
Where is a problem ?
BR
Marek
Replies (9)
Message 2 of 10
m.podsiadlowicz
One more attachment.
The error occurs when projecting a rotated detail.
Message 3 of 10
HughesTooling
Is seems to work OK for me. PDF's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 10
HughesTooling
Can you go to your online dashboard and export the 2d drawing as a Fusion archive, you should end up with a fz3 file. Also what OS are you using and have you tried closing and restarting Fusion?
Mark
Mark Hughes
Message 5 of 10
m.podsiadlowicz
I don't know why your drawing is OK.
I repeated the export to DRAW and I have it as I had it, which is wrong.
Yes. I restarted Fusion. Windows 10.
Message 6 of 10
m.podsiadlowicz
Archive which i maked
Message 7 of 10
HughesTooling
No archive attached. You will need to use the forum not email and you will also need to ZIP the design or the forum software will block the upload.
Mark
Mark Hughes
Message 8 of 10
m.podsiadlowicz
im trying
Message 9 of 10
HughesTooling
I can see the problem in your drawing and it also shows if I add more views. If I create a new drawing from your part I don't see any problems so not sure what's wrong. @TimeraAutodesk  Can you help with this?
Thanks Mark
Mark Hughes
Message 10 of 10
m.podsiadlowicz
I repeated the operation.
This time the error is in the top view.
A4
Base view : botom
rotate : 135 deg
