- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I usually model things in 3D before creating 2D drawings. I used Inventor for a very long time but my new boss basically said that we need to use Fusion. So alongside Fusion, I use AutoCAD to draw in 2D because Fusion's 2D is really bad IMO. But I just realised that every time I create a drawing from a 3D model in Fusion and then export that really basic drawing (basically just projections) as a DXF the drawing has depth. So basically every line is placed in a 3D plane with Z coordinates all over the place. And because the lines have different Z coordinates the snapping in AutoCAD won't work correctly.
So the question is do I do something wrong while exporting or do I need to enable something in Fusion so the 2D drawings are going to be really 2D or is this just how it is?
