Drawing Dimensions over broken views (Break view) incorrect on edge extension
b.affa
Message 1 of 12
b.affa
Please be very careful when dimensioning broken views – if you pick an edge extension as one of your points and span over a broken view, the dimension will be wrong as seen in the image below.
The dimension value is equal to the actual scaled distance in the drawing, which is arbitrary.
It is very easy to miss especially if you do ordinate dimensions.
Replies (11)
Message 2 of 12
jhackney1972
I cannot replicate the issue you are pointing out.  I have attached my model, try it out in a drawing and see if you see the issue.  Also, please attach your model so I can do the same.  Open your model, select the File menu, then Export and save to your hard drive.  Attach it to a reply post using the attachment section.  Model is attached.
John Hackney, Retired
Message 3 of 12
-KyleWilliams-
Hey @b.affa
I've also tried to recreate your issue and don't seem to be having unexpected results.
This part is symmetrical and as you can see the extension side gives the same value as the non.
If you are able to share your drawing with the incorrect value we may be able to dig deeper to solve this.
You can send it directly to me [email protected]
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
Message 4 of 12
g.buckleyZPK86
Hi Kyle,
  I can replicate the issue from b.affa - came across this recently.
It also does the same behavior for ordinate or normal dimensioning. You need to select the edge extension and dimension anything over a break view..
This also one seems to happen "some of the time".. re-do it a couple of times and you'll get some scaled dimensions.
Gareth
Message 5 of 12
b.affa
This bug applies on models with filleted (& possibly chamfered) corners that have the edge extension tool applied to the corner.
Message 6 of 12
jhackney1972
Yes, you are correct.  The Edge Extensions DO cause the Broken View to dimension incorrectly.  The highlighted dimension should be 20.00.  Good catch!
@ClintBrown3D, Model and Drawing are attached.
Message 7 of 12
Pramod.kadam
Hi All,
Thanks for reporting. This is known limitation. We have item logged in our backlog to enhance this. We will update you as soon as this gets prioritised.
Pramod Kadam
Product Owner
Fusion 360 Drawings
Message 8 of 12
saso_grinaver
Maybe it's time to fix this now?
I mean it's basic tool and we need this...
Thanks...
Message 9 of 12
CGBenner
@RajkumarIlanchelian has there been any update on this?
Chris Benner
Message 10 of 12
Pramod.kadam
Hi All,
Unfortunately, This is not fixed yet. The problem little complex than expected, we will update you as soon as we plan this.
Pramod Kadam
Product Owner
Fusion 360 Drawings
Message 11 of 12
haldavis2000
Any update on this? It's been nearly 3 years.
Message 12 of 12
NDiClaudio
I'm having the same issue, trying to apply an ordinate dimension over a Break View using an Edge Extension as my 0,0.
Many of my drawings require this functionality.
Any update on this @Pramod.kadam ?
-Nathan
