Drawing Dimensions Incorrect
I've seen a number of posts about this already (https://forums.autodesk.com/t5/fusion-support-forum/drawing-dimensions-are-incorrect/td-p/7831924) but all of the posts I've read seem to refer to issues with adding dimensions to isometric views or to views with curved objects. I'm having issues with incorrect dimensions for both base views and section views.
In the attached video you can see that in the design mode, the height of the lip is 1/8", while in drawing mode the height is 1/4". I noticed the same dimension issue with using flat, orthographic section views as well, What am I doing wrong?
Edit: my bad, it looks like the precision was not high enough so it was rounding. I can't seem to find a way to delete this post.
