Drawing 2D
Drawing 2D
cncWNGXZ
Observer Observer
Message 1 of 9
Drawing 2D
cncWNGXZ
Observer
Observer
the lines do not appear for me when I switch to draw2025-12-09 15_53_08-.pnging.
Replies (8)
Message 2 of 9
jhackney1972
Go to you Preferences and select a different Graphics Driver.  I would suggest DirectX 11.  You will have to restart Fusion when you change to a different driver.
John Hackney, Retired
Message 3 of 9
TheCADWhisperer
@cncWNGXZ
I do not see any views created on that sheet.
What happens if you click on the first sheet in lower left corner of screen?
What do you see if you expand the Sheet Settings?
Message 4 of 9
lance.carocci
@cncWNGXZ Can you please provide a screenshot of the readout from Help > Support and Diagnostics > Graphics Diagnostic?
The option in Preferences > General is actually limited to the 3D modeling canvas.
For Drawings, you can attempt to override the graphics API using environment variables.
  1. Create an environment variable named GS_DEVICE
  2. Set the value to one of: Dx11, swDx11, Dx12, swDx12 or OGL
    • It is likely already trying to use Dx11, so try OGL too
    • The options prefixed with "sw" are software rendering, so may be slower performance but more compatible
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 5 of 9
cncWNGXZ
Observer
Observer
[GPU Information]
GPU Device: AMD Radeon HD 6570
GPU RAM: 1024 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 15.201.1151.1008
GPU Driver Date: Unknown
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
Message 6 of 9
cncWNGXZ
Observer
Observer
 Sheet Settings
Message 7 of 9
cncWNGXZ
Observer
Observer
If I print to PDF, it will look like this.
Message 8 of 9
lance.carocci
That's why. This chipset's last driver update was 10 years ago. You could try forcing software rendering, but there is no guarantee this device will work with Fusion.
Lance Carocci
Message 9 of 9
lauri_barnhart
Hello, @cncWNGXZ,
Did the information provided by @jhackney1972, @TheCADWhisperer or @lance.carocci help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
Let us know how we did on Trustpilot.
