Dragging Items in Design History Timeline
aferberDJH6P
Observer Observer
Message 1 of 11
aferberDJH6P
Observer
Observer
I have been scouring the internet for awhile, including these forums, and I have seen similar questions asked and resolved, but nothing seems to address my particular circumstance. Apologies, though, if this is a duplicate of another thread. Please point me to the dupe!
I cannot seem to move any objects in the Design History Timeline.
I am new to Fusion 360, and following this tutorial, which, admittedly, is a little dated now, but is still fundamentally sound. At about 15:08, he drags an extrusion from its place, and drops it after another sketch, so that the extrusion cuts both its original sketch and the newer one as well. When I try to do so, no elements in the timeline even make a pretense of moving. All the posts I've been able to find reference not being able to move objects before their dependencies and other such limitations, but I am not trying to do that. It's as though this feature is locked somehow, but I have not been able to find any reference to a setting or methodology that would lock the entire timeline.
Attached is screen capture that hopefully shows the behavior. Here is a link to the project as well: https://a360.co/3KXma4g
I also opened a new document, added a couple of sketches with extrusions, and still couldn't move anything. So this points to something weird with my Fusion install, my settings, or something like that. I did also make sure I was fully updated and restarted Fusion (and rebooted the computer for good measure).
I am super stymied, so any suggestions would be marvelous.
Replies (10)
Message 2 of 11
jhackney1972
I used your model to demonstrate how to make one of your features capable of being moved in the timeline.  You already have two features that are independent, the end boss and the lug on the end.
(view in My Videos)
John Hackney, Retired
Message 3 of 11
jhackney1972
Here is another example of using my Timeline to make my work easier.
(view in My Videos)
Message 4 of 11
aferberDJH6P
Observer
Observer
Wooaahhhh....OK, clearly there are some fundamentals I do not understand yet, mostly about projections. It will take me some time to grok your explanation and be able to use it, but thank you so much for the reply, and for being so clear with the explanation.
Message 5 of 11
jhackney1972
Basically think, if my sketch and feature is based on another feature, you cannot drag that feature back in the timeline PASS the sketch or feature it is dependent on.
By the way, you need to start using the "Reply" icon on the Forum post of the person you are addressing.  The way you are doing it is addressing the post to yourself.
Message 6 of 11
Julie_7
The problem is that the timeline does not have any hierarchy. It doesn't respect component boundaries. Changes to an active component always go at the end of the timeline (meaning where the end is currently positioned) and you can only change the timeline if it is positioned at the absolute end.
And, there is no way to see the dependencies that prevent you from restructuring your design.
Message 7 of 11
davebYYPCU
I disagree with the last statement, as you drag the timeline icon, left, it will only go as far as is legal.  Live time showing the dependency.  As in most software, you got to follow the Rules.
The Timeline is chronological, it works.
Might help....
Message 8 of 11
Julie_7
I will agree that the timeline is chronological and it works. I don't think it works as well as it could.
If I have a component active, I think making a change to that component would be more intuitive if it was made to the end of the current timeline for that component. Instead it goes at the end of the timeline which results in a timeline with features all over the place and not grouped by component, just because I didn't think to do that particular step when I originally created the component.
The solution is to roll the timeline back to the last feature in the component and then activate the component and then the feature goes where I want it to. This is very time consuming with a long timeline, especially if the features for the component are not contiguous. (I did just think to look for an easier way while writing this and found that the context menu for the component in the browser will show the component in the timeline.
When I do find the component in the timeline, it would be helpful if the context menu for features of a component had a choice to activate the component. This is usually necessary because I likely had the main component of the design selected to allow navigating the entire timeline.
Most of my problems stem from my long career in software development. We constantly refactor code to group the things that belong together, make the structure more correct and understandable, make software components more independent. This carries over to CAD design for me. I never get it right the first time. Parameters and being able to go back and edit features makes Fusion 360 so good, but when trying to rearrange structure and manage dependencies it gets very hard.
Rules for Timeline Changes
I am still trying to learn all the rules. At one point I had read that the marker must be at the end of the timeline to move a feature. I now know this is not true because I just moved a feature with the timeline marker just after the feature.
It is obvious that you can't move a feature before a feature that it depends on, but there are times when I can't move a feature to the left, and it does not depend on anything but the very first sketch I made when I started the design. And, as far as I know there is know way to get Fusion 360 to tell me what is blocking the move.
I have also gotten into the case of cyclic dependencies and had no way to see those dependencies. I finally had to just delete a large chunk of my model to get back into a working state.
Because the timeline does not treat components as groupings, I cannot move an feature in the timeline into the sequence for a component and then make it part of that component. To move a body or sketch from one component to another I have to drag it in the browser. Sadly that adds the move body to the end of the timeline. Not what I want at all.
There is no rule that stops me from deleting a feature from the timeline that has other features depending on it. Fusion 360 knows about those dependencies. It even warns me that deletion will affect following features. If I delete the item then some features may have errors and others just get silently deleted. This has to be the worst timeline issue out of all of them. Fusion 360 knows there are dependencies, and it knows exactly what they are because it acts on that knowledge to change the design, but it won't tell me what they are. At a bare minimum, when the warning pops up telling me that deletion of a feature might cause downstream failures it could highlight all the features in the timeline that are going to be affected. I could use an more obvious highlight for features that are going to be removed.
Dependencies
Dependency management is a very complex and significant part of developing any kind of component based system. Without proper dependency management components cannot be shared, reused, improved in the most useful and efficient way possible.
Not making the dependencies visible and manageable by the user prevents the user from creating the best designs possible.
Message 9 of 11
Julie_7
While the timeline works, it is not easy to use. When drag doesn't work, I cannot get information why it does not work.
What are the rules?
Please provide a link.
Message 10 of 11
davebYYPCU
I don’t know if there is a link,
I learnt the way you have described it.
The only thing you have not mentioned is the timeline component colour swatch.  Very helpful to establish which component to activate.
Beggars belief that you Delete anyway.  One way to find the dependency I suppose.
Message 11 of 11
sebastian1_mejia
This is just an example of how Autodesk doesn't care about user experience whatsoever. It is typical and shameful.
@sebastian1_mejia - this post has been edited due to Community Rules & Etiquette violation.
