Dpi isue after last update
mbelusa.mail
mbelusa.mail
i have Dpi issue after last update. Before update was everythings OK.
My laptop HP Z-book 14
Resolution: 1920x1080
Dpi set to default: 150
This steps not working for me:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Performance-Tips-f...
Now are all items,icons big and  displayed blury and
Thank you!
davideromeo.d
Exact same bug in Windows 11 22H2 DPI:125% 1920×1080.
All the help options in the previous link have been tried without any success.
mbelusa.mail
On second PC in office same issue 😞 , tried everything include total clean reinstall .... Why autodesk send unstable updates to the word ??? I need work fusion for work not for playing 😞 Hope someone from Autodesk team fix it asap.
viaD6QPP
I have the same problem, only helps to set the DPI to 100%, but then it is not convenient to use Windows.
erock89x
Im also paitenly awaiting a solution.
canaltay
Community Visitor
Community Visitor
Same problem here, did anybody found a solution or are we waiting for Autodesk to fix it in the next update ?
LishuangLu
Thanks for reporting this issue to us!
In the latest Fusion update, there's a fix to address the blur issue caused by system DPI change. But need apply the workaround as below:
Windows:
  1. Right-click the desktop icon for Fusion 360.
  2. Select Properties.
  3. Select the Compatibility tab in the dialogue that appears.
  4. Click Change High DPI Settings.
  5. Deselect Override high DPI scaling behavior.
Let me know if this still doesn't work for you after upgrading into the latest Fusion update and turn on above workaround.
-Lisa
