Double vision when creating new base view
crETN6H
crETN6H
I have a drawing I've created from a design. The first base view that inserts when you first create the drawing is fine and normal, but when I insert another base view, it seems to be weirdly doubled. Any idea why this is happening?
crETN6H
Here's another screencast:
https://autode.sk/3IDNhwg
Here, it shows I can get rid of the doubling of the chassis component by turning off the chassis in the new base view. Which is a work-around that sort of solves my immediate problem, but it still seems like either there's a bug or something I don't fundamentally understand.
crETN6H
Figured it out! One of the components (the bottom) is derived from another component (the chassis), so there's a copy of the chassis in the bottom. When I create the new base view it turns visibility for everything on, regardless of how it's set in the design. I just needed to turn it off:
https://autode.sk/3LiGKJ5
