Doesn't update after changing the position of the refered plan
Florian__
Florian__
First I created an axis threw a cylinder. Then a plane that is defined by the axis and an angle. Afterward I created a section view that is set on the plane.
The issue is, that if i change the angle of the plane the section view is still be on the old position and doesn't update.
The only way to fix it is to reference the section view again.
Does anybody has the same issue or is there already a solution? Thanks!
jeff_strater
yes, that is a known limitation in the analysis commands - section analysis is not associative to a plane.  There is no real workaround other than editing the analysis and re-selecting the plane.
The Fusion item for this is FUS-60957
Jeff Strater
Engineering Director
jeff_strater
I am happy to report that I was notified that this bug is now fixed in an internal build.  As usual, it will take some time to work its way to the outside world, but a fix is on the way.
Jeff Strater
