Displaying extruded dimension of an extruded component
jeff_limEW2C6
Message 1 of 9
jeff_limEW2C6
How do I display the dimension of an extruded surface in a 3d view. Use case:
1) I sketch a rectangle 80mmx90mm
2) I offset the rectangle by 2 mm
3) I extrude the sketch by 80mm
4) I select the sketch and select the show dimensions option
5) Go to 3d view , i can see the height and width of the component
6) I can measure the component's extruded length using the inspect function
7) How do I display that extruded length in 3d view
See the attached images - First is what i get , 2nd is want i want to show
Replies (8)
Message 2 of 9
davebYYPCU
Can be done, but why?
Message 3 of 9
jeff_limEW2C6
As I am trying to design something that has several components assembled along its length and I want to describe the finished item in a single 3d view. I find i am having to do a manual sketch to keep track of things.
Message 4 of 9
davebYYPCU
Yep, side view sketch with driven dimensions, at the end of the timeline,
or Create a Drawing.
Might help…..
Message 5 of 9
jhackney1972
Here is a model showing what @davebYYPCU is talking about.  Model attached.
John Hackney, Retired
Message 6 of 9
JoshuaO_
Another way is to make the sketch first and then extrude to a sketch object (like the endpoint of a line). This would allow you to edit the dimension in the same manner as the previous two.
Message 7 of 9
jeff_limEW2C6
This is a better work around. I like this way better, it keeps the project cleaner.  I am surprised, for what is otherwise such a powerful and intuitive tool, being able to do this as a display option on an extruded object is not a standard feature. Maybe in some future version.
Message 8 of 9
davebYYPCU
It’s not a popular request,
my suggestion, creates clutter, and duplication, of existing data, hence the question.
@JoshuaO_ solution is very common, and most of us would be using that workflow, and then hiding the sketch, is the default for single use sketches.
Might help…..
Message 9 of 9
TheCADWhisperer
? It’s a Standard.
