direct x compatibility
michaelplummer
Observer Observer
michaelplummer
Observer
Observer
hello all
i am attempting to change fusion from running on direct x 9 to 11 as 9 will no longer be supported, i can change the version in preferences, but then i am unable to see any model when loaded. my laptop is windows 11 and shows to be running direct x 12. any help would be much apricated
thanks
michael
LishuangLu
Hi @michaelplummer, thank you for reporting!
Would you please share with us the Fusion Graphics diagnostics info by following the step?
  • Go to Help, Support and Diagnostics, Graphics Diagnostics, Copy to Clipboard.
  • Then paste the information here.
With the graphics diagnostics info, we can help review if it's a hardware specific issue or not. And as a temporary workaround, we recommend you can continue running with DirectX9.
Lisa
michaelplummer
Observer
Observer
Hi Lisa
sorry for the late reply, please see attached
thanks
Michael
[GPU Information]
GPU Device: AMD Radeon RX 6600M
GPU RAM: 8192 MB
GPU Driver API: DirectX 9.0
GPU Driver Version: 32.0.12033.1030
GPU Driver Date: Unknown
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
michaelplummer
Observer
Observer
also please see when i run dxdiag
thanks
michael
