Dimensioning problem after last update
kbowen3995
kbowen3995
I have attached a screencast of a problem I have having on simple parametric dimensioning. For some reason it is not picking up the two lines I am selecting but picking a non existent point in space.
https://autode.sk/3lUxNLb
sanjana.shankar.goli
Autodesk Support
Autodesk Support
I see that you are adding a dimension between a centerline and a construction line. Dimensions from centerlines come up as diameters. You can change the centerline to a construction line from the sketch palette and dimension it correctly.
More information on this here.
Sanjana Goli
Software QA Engineer
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
