Dimension Text Missing
CruftMeister
Message 1 of 18
CruftMeister
Folks,
Since one of the recent updates, I'm noticing that in some files Fusion stops displaying the dimension text.  The dimension lines, extension lines and leader line are all showing and you can double click on the end of the leader and get the dimension entry box to show up, but the dimension value remains hidden after the entry box closes.  Show/Hide dimension appears to have no effect.
Screenshot attached.
Replies (17)
Message 2 of 18
masa.minohara
Hi @CruftMeister ,
Thank you for posting in the forum! Would you mind sharing a public link to the design that you are experiencing the issue with so I can investigate?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 18
CruftMeister
Hi Masa,
I have invited you into the project but have discovered that this behavior only happened on one of my machines, the other (both are Macs) is fine.  Very curious now though is that on the machine that demonstrated the issue I can no longer launch Fusion - it just hangs on launch - so it appears that the install has become corrupt.  I will uninstall and reinstall and try again.
Message 4 of 18
CruftMeister
OK, I used the uninstaller to completely remove Fusion from my laptop (MB Pro) then reinstalled from ther latest installer.  The behavior is still occurring on the laptop, but not on my desktop machine (Mac Pro).
Thoughts?
Message 5 of 18
masa.minohara
Hi @CruftMeister ,
Thank you for your response! It seems like I have not been invited to your project. Would you mind sharing a public link to your design with me?
Also, I assume it may be related to your graphics card. Could you attach your graphics information as well?
Masanobu Minohara
Message 6 of 18
CruftMeister
Hi Masa,
So that you know, I've been using Fusion on the affected system (MBP) for months without issue until now. I've not made any configuration changes to the system and only noticed the problem after one of the most recent updates, hence my conclusion that it was a Fusion issue, but who knows.
As I mentioned before, this file is part of an ongoing design and I am not at liberty to share it publicly.  I tried inviting you by inferring your email address, but that must not have worked. As I can not share the file where I discovered the issue, I have shared a different file that is non-critical but also shows the same behavior - URL & Graphics Diag below.  At some  point, Autodesk should come up with a better solution than sharing files publicly to get support - that really isn't a viable solution for many of us.
URL:
https://a360.co/2OlSM8c
Graphics Diagnostic:
[GPU Information]
GPU Device: AMD Radeon Pro 560X
GPU RAM: 4096 MB
GPU Driver API: OpenGL Core Profile
[Graphics Effects Settings]
Use high-resolution graphics: Off
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Let me know if you need me to tweak any settings within Fusion.
Art
Message 7 of 18
masa.minohara
Hi Art,
Thank you for your response. You can share a public link via private message and that way you don't need to post a link publicly.
In the design you shared in your previous post, which sketch are you seeing the issue with? Are you seeing the issue with all the sketches in this design?
As a quick test, could you try switching the Graphics driver setting to OpenGL to see if that makes a difference?
Masanobu Minohara
Message 8 of 18
CruftMeister
Hi Masa,
Yes, I was seeing that behavior in any of the sketches that I opened.
I just tried setting Graphics to OpenGL. That railed the CPU for some time when Fusion launched, but did not solve the issue.
Any other ideas?
Art
Message 9 of 18
masa.minohara
Hi Art,
Thank you for your response. I'm having difficulty reproducing the issue and not sure what's causing the issue for you at this point.
I'll check with the internal folks and post more information as soon as I have one.
Masanobu Minohara
Message 10 of 18
masa.minohara
I just noticed there is another forum post with the same symptom here. In this forum thread, it seems like the root cause was a missing font, and installing Arial font fixed the issue.
Do you have Arial font installed on your system?
Masanobu Minohara
Message 11 of 18
CruftMeister
Hi Masa,
Ah, too bad, I looked in the Font Book on that machine and Arial is loaded, but that would make sense.  Any other thoughts?
Art
Message 12 of 18
masa.minohara
Unfortunately I'm not sure what else we can try to fix it right now. I'll check internally and keep you updated.
Masanobu Minohara
Message 13 of 18
CruftMeister
Hi Masa,
Understood, thanks for giving it a shot.
Art
Message 14 of 18
Hi!
Did this issue ever get resolved? I'm running the most recent Fusion 360 on a Macbook Pro. Arial fonts installed & can't find anything else online in the past year re this.
Cheers!
Message 15 of 18
CruftMeister
Hi Niallbell,
I had to submit a support ticket to get this resolved, but the good news is, it is fixable.  The fix was to copy the Arial Fonts into the Mac System/Library/Fonts folder (see screenshot from support case 15504314 )
https://www.dropbox.com/s/rfx5oh480niiv0o/Arial%20Fonts.zip?dl=0
I put a dropbox link of the Font zip they sent me above.  Maybe give this a try and see if it fixes the issue on your system. Other than that, you can always submit a ticket and refer to the above case number.
Art
Message 16 of 18
It’s ok now , tank you for your help.
Message 17 of 18
jlp6k
Observer
Observer
Even if it's an old topic, I stumbled upon the same problem.
This is a sketch from a quite large project (at least for me) with about 15 sketches (some are sharing points, some are 3D sketches). As you can see, some dimensions appear normally (both driving and driven) but on some others, the value isn't displayed.
I checked if my font folder contains the necessary Arial fonts listed in the @CruftMeister 07-24-2019 post.
I tried to reinstall Fusion 360.
I also tried to export and then import the projet.
None of these solved the problem.
Any suggestion?
Message 18 of 18
jlp6k
Observer
Observer
Today the missing dimensions have reappeared!
It's a good news but it's a bit scary. So, if someone has an explanation it will be good.
