Dimension Depending is moving in the wrong direction
Message 1 of 20
Hi
If have a strange behavior. If i set a dimension on a existing sketch the dimensions moving in the wrong direction. I dont see the reason and because of the depentions i cant move it in the right direction anymore. How i am able to solve the problem or what i am doing wrong. The result is calculation right but not my itention. How i can force the line going in the itented direction.
Screencast:
1acb7fac-b5d2-4751-9135-fcb61560d31e,640,620
Replies (19)
Message 2 of 20
I think i found the solution by my self. I can fix points. So they unable to move. If i fix the right points the direction of the dimension is moving in the right direction. Please answer if there are any other solutions.
Edit: Its only a temporary solution. If i lose the fix, all following makings of dimensions are doing the same effect.
Screencast:
https://knowledge.autodesk.com/de/community/screencast/e8bd7aae-b14e-4ff5-9f41-a4d215329c80
e8bd7aae-b14e-4ff5-9f41-a4d215329c80,640,620
Message 3 of 20
TheCADWhisperer
I have seen this behavior frequently in Fusion 360.
File>Export and then Attach your *.f3d file here so that @jeff_strater has another example.
Message 4 of 20
jeff_strater
yes, please.  Share the model.  Thanks
Jeff Strater
Engineering Director
Message 5 of 20
Thx, for the answers. If i am export the single part the problem disapears. The problem is only there if i being open the sketch within the construction. I think its an problem with a dependency with an other part of the construction. I will provide the whole construction. One of the problem is within the sketch of "MonsterMittelDeckelLinks" Part. Try to change the dimention 122mm.
Message 6 of 20
jeff_strater
@Anonymous - thank you for sharing the model.  The behavior is quite reproducible, and I'll send it to the sketch team to take a look.
the Fusion bug is:  FUS-65558
Jeff Strater
Message 7 of 20
gdcm1964
another newbie question. I'm having the same issue. I want the line below the red arrow to move down in the dimension setting but the bottom line moves up.
What am I doing wrong? 🙄
Message 8 of 20
g-andresen
1. create a relation to the projection (magenta) or create one to the body edge.
2. Bring the two vertices to the same height.
günther
Message 9 of 20
gdcm1964
thanks for the reply but..I'm brand new to fusion and have no idea how to create a relation or constraint.
Message 10 of 20
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the post.
günther
Message 11 of 20
gdcm1964
I should have checked here before I deleted it.
I'm going to start from the beginning again. when I get to that point I will share the file. 🙂
Message 12 of 20
g-andresen
maybe the screencast will help with the next action
(view in My Videos)
günther
Message 13 of 20
gdcm1964
my apologies for the late response.
I've started the entire thing over about 6 times to finally get to where I will be starting the lid again..
I've watched your video a couple of times but if there is audio I can't hear it.
Message 14 of 20
g-andresen
there is no audio but some callouts for better understanding
günther
Message 15 of 20
gdcm1964
Well I managed to get past that issue on attempt #2..
then this happened. I think I figured out why..the origin is on the very edge of the feature and it should be in the center.
Can I move the feather to accomplish that?
Message 16 of 20
g-andresen
günther
Message 17 of 20
gdcm1964
I thought I save it but I didn't.
I'll recreate it later today and post it.
Message 18 of 20
gdcm1964
I "think" I know what the problem is, I just don't know how to fix it.
In Lar's video his origin is in the middle of the lid. Mine is off to the side.
Message 19 of 20
g-andresen
Replace your plane 1 and select symmetrical extrusion
(view in My Videos)
günhter
Message 20 of 20
gdcm1964
thank you for taking the time to do that.
I managed to get it in the right spot eventually using the mid plane tool but I will try it this way as well...a guy can't have to many options. 🙂
I managed to do this project tonite as well...
I must say I'm having a lot of fun learning how to use this program..
what is the secret here to get pics to show instead of a link?
