Dimension based on driven dimension divided by user parameter not updating in sketch?
KristianLaholm
KristianLaholm
Problem / Bug:
Driven dimensions divided by User Parameter is not updating in sketch?
Changing the user parameter "Count" should move the circle up/down along the side (change dimension d7).
The value in dimension "d7" change but the sketch is not updated until i drag the circle.
Finish sketch is not updating the sketch.
"Compute-All" will update the sketch.
File attached.
(view in My Videos)
Windows 11 / Fusion 2.0.18961 X86_64
g-andresen
I can confirm that.
A job for @Phil.E ?
günther
Phil.E
It will compute if you exit the sketch and use Compute All.
I've passed this to the sketch development team. Thanks for reporting it and providing a file.
Phil Eichmiller
Software Engineer
Quality Assurance
sameer_babarNJS6C
We have analyzed above issue and it is reproducible for us with part provided and with new part as well.
We have logged a ticket FUS-156941 for it , we will update you once we have a fix for it.
Sameer Babar.
Autodesk Fusion Team.
