Detailed Info on Intermittent Lockup
- Mute
- Permalink
- Report
Ok so I have been experiencing HUGE Lockup issues of late. Ive posted in a couple of the other threads on the issue with no results forthcoming, so this time I watched and recorded what was going on.
At 14:26 today, fusion took a long time to open the first file i selected to open. this is a shot of what it was doing while the beach ball spun, taken from the console view of the log file for that session(note brand new session, first file opening)14:34:18 System Locks when I select Hide for model components
So I am able to work for about 8 min until 14:34:37 when I Attempt to Hide a bunch of model components, Log window continues to show the same uploading messages continuously through out the lockup. Note that during this time there is no apparent network or Disk activity
14:34:37 Log Activity
14:34:24 Fusion Beachball
14:34:50 Fusion Not responding
Then At 14:38:41 suddenly the Lock up ends the command is executed and things are working again, meanwhile the smae set of messages continue to scroll. The log shows the command request as well as a number of autosave commands etc.
14:38:41 Fusion Wakes Up
14:39:04 Log Window activity
Also attached you will find a copy of the session log file for your review.
This IS REALLY HAPPENING!!!!!!! about every 10 min and it is destroying my ability to use the software!
Please look into this without requesting I clear my caches etc, which I have already done.
Attached also are the Diagnostic log files
Here is the Graphics INfo
[GPU Information]
GPU Device: NVIDIA GeForce GTX 980 Ti
GPU RAM: 6144 MB
GPU Driver API: OpenGL
[Graphics Effects Settings]
Use high-resolution graphics: Off
Anti Aliasing: Off
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Display
[Limit effects to optimize performance]
Off
Look forward to some Quick and REAL attention to be paid to this issue that I and others are experiencing since the last Update.
Jason
