Designs will not be linked
mikeYEAME
Message 1 of 9
mikeYEAME
I am a hobby user. Following the move to teams when I try to insert a design as a component into another design in the same project folder I get the message "Designs inserted from another hub will not be linked. Components from the selected design will be copied into this design" This happens even when I have started the component from scratch. I would like to be able to maintain the ability to maintain the designs , is this possible? Mike
Replies (8)
Message 2 of 9
RajkumarIlanchelian
@mikeYEAME Please run the below workaround and that should address the problem.
  1.  Close fusion
  2. Go to - C:\Users\kumarpra(use your id)\AppData\Local\Autodesk\Autodesk Fusion 360
  3. Back up folder Autodesk Fusion 360 and then delete this folder
  4. Go to -  C:\Users\kumarpra(use your id)\AppData\Roaming\Autodesk\Autodesk Fusion 360
  5. Delete folder Autodesk Fusion 360
  6. Relaunch fusion
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 9
mikeYEAME
Hello The workaround worked great Thank you
Message 4 of 9
MrB0t
Worked for me too. Thank you.
Message 5 of 9
The.Justin.Gibbons
Worked perfectly. Thanks.
Message 6 of 9
Thole01PUZ3C
Observer
Observer
Worked Flawlessly. Thanks.
Message 7 of 9
littlenyancat204
Also worked for me, although I'd prefer that Autodesk didn't force workflow-breaking changes on their users...
Message 8 of 9
ballargr
Community Visitor
Community Visitor
worked for me as well. really annoying to run into this.
Message 9 of 9
stuart.simpson
Thanks this worked like a charm.  I guess the local cash was out of sync and had to be recreated. Thank you for you help.
