Designs can't be moved or copied....
Velekh
Message 1 of 12
Velekh
Ok, I get that I screwed up by moving my files from eagle into a single Fusion project.  But now that I understand Fusion properly, I want to move everything into individual projects. Sounds simple but move doesn't work, copy doesn't work, export doesn't work, ....how do i move my files?! I've tried in Fusion and get errors that "you can only save this design in this folder" or it just fails outright, and on hub, I get "failed to copy/move".
Replies (11)
Message 2 of 12
jhackney1972
I cannot tell if you followed the standard process for moving files from your description so I made a Screencast showing the process from the Fusion 360 Data Panel.
John Hackney, Retired
Message 3 of 12
Velekh
I  have tried that process as well as attempting to use myhub on the web.  The view you have in Fusion with the projects does not exist  for me, I only see the folders of the current project.
Message 4 of 12
jhackney1972
It would be helpful if you created a Screencast of your own to show your process and exactly what you are seeing.
Message 5 of 12
Velekh
unfortunately a screen cast is too much editing work, here are the views and stills of what happens however.
Velekh_0-1653607704711.pngVelekh_0-1653607704711.pngVelekh_1-1653607882383.pngVelekh_1-1653607882383.png
Message 6 of 12
Velekh
did my request get abandoned once again?!
Message 7 of 12
Velekh
Can someone please help?
Message 8 of 12
Velekh
@jhackney1972 are you still assisting?
Message 9 of 12
jhackney1972
Yes, I still try and help others find solutions.  The last thing I ask, of you, was a Screencast to show the process you used to move folders and files and you said it was to much work.  Instead you supplied some screen shots which really do not show the process you use.  You said you did not see the same thing I demonstrated in my Screencast, I would like to see what you experience.  I do not claim to know what your solution is but would love to get the tools to try and find it for you.
Message 10 of 12
Velekh
@jhackney1972
Cast of App:
https://autode.sk/38T4O7N
Cast of Web:
https://autode.sk/3xd1I6T
properties of file in attempt:
Message 11 of 12
jhackney1972
I took a look at your Screencasts and do not see anything that would explain your issue.  I will agree with you, your Move dialog box is much different from what I see especially that it does not show your Project listing.  I hope that someone else can find something I have missed.
Message 12 of 12
Velekh
Autodesk? anyone able to assist?
