Dawing template missing notes
anbarasanEF7QV
anbarasanEF7QV
I have a saved drawing template with drawing notes, parts list, title block and revision table.  But every time when I create a drawing from design using that template. It just opens an empty drawing with an incomplete title block and the notes, part list and revision tables are completely missing. What could be possible reasons for this error?
I'm completely not able to create any drawing with a custom template which I was able to do before. Even saving the current template with a new name doesn't work.
Experts advice awaited!
Thanks!
nemadec
Hey @anbarasanEF7QV,
It would be helpful for us, if you can share the template here or in person.
We will look into this issue.
Chandrashekhar Nemade
Sr. SQA Engineer
pramod.pk2XX6G
Hi @anbarasanEF7QV
Thanks for posting.
I understand that when you try to create a new drawing by using a custom template - the drawing is blank with missing border and title blocks.
Could you try to create a new drawing after resetting fusion 360 using the server utility? see Overview of Reset Fusion 360 Command from Fusion 360 Service Utility
If you are unable to reset the fusion by the above-mentioned steps in the article Go to the control panel > program and features > right-click on Fusion 360 > Change > reset Fusion 360.
By any chance, if the Fusion 360 does not work on your machine, try saving the drawing template with a different name in a different project (location)and try to create a new drawing.
Hope this will be helpful,
Pramod
anbarasanEF7QV
Hi Pramod,
I tried resetting the fusion and saved the template in a new name in a
different folder. But nothing worked. Still, it's not working.
anbarasanEF7QV
Hi Pramod,
I tried resetting the fusion and saved the template in a new name in a different folder. But nothing worked.
anbarasanEF7QV
I moved the template to a different project folder and still not working.
