Data panel : can't change status from editable to read-only
ecommerceF4JR7
ecommerceF4JR7
My data panel doesn't work :
if you click on a project the preceding project opens,
if you click on editable below a project,
nothing happens
Phil.E
Thanks for letting us know.
Can you confirm which build you are using, from the Help > About box?
Have you tried restarting your computer?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
ecommerceF4JR7
Fusion 2.0.19215 x86_64
I tried rebooting the computer,
I also reinstalled Fusion but no change
Phil.E
It might help if you made a video showing the steps you are taking, if you have time.
Are you using the "editable" list in the data panel, or browsing into the projects?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
ecommerceF4JR7
here is a video, if I click on an item, the preceding item opens, and I can't change the read-only status
(view in My Videos)
Phil.E
If I'm interpreting this correctly, the mouse clicks in the data panel are hitting targets that are above the intended target. This might be why the editable tool is not responding when you click it.
This could be a graphics hardware issue. Are you using UI scaling or a second monitor?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
