Dark theme problem - white windows
Radko29
Message 1 of 17
Radko29
I switched to dark theme today, but unfortunately the windows are white. How can I fix this?
Windows 11
Replies (16)
Message 2 of 17
jhackney1972
Have you followed the instructions given in the What’s New document?
A quick note: If you previously adjusted the Display Settings Environment to a custom canvas color, your settings will remain unchanged. If you’d like the canvas color to match your selected UI Theme, head over to the Navigation Bar > Display Settings > Environment and choose Theme (default).
John Hackney, Retired
Message 3 of 17
Radko29
Unfortunately, that didn’t help. I even restored the fusion settings to default, but the same issue remains. When I apply the dark theme, everything looks fine for a split second, and then the windows turn white.
Message 4 of 17
marko2F5G6
Same issue here, only I am running windows 10. Tried changing windows settings to default and resetting the Fusion, but nothing helped. If you find a solution please post it here.
Message 5 of 17
spencerpberndt
Community Visitor
Community Visitor
I'm having the same issue on my windows 11 laptop with a 4k monitor and intel arc gpu. Any updates on this?
Message 6 of 17
andreyjb15
Observer
Observer
Same issue here
Message 7 of 17
jhackney1972
I am using the Gray Room Environment.  I adjust my Preferences as shown and as you can see I do not get the issue you describe.
Message 8 of 17
lauri_barnhart
Hi @andreyjb15,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
Message 9 of 17
Radko29
The problem still exists and has not been resolved. Changing the settings does not help.
Message 10 of 17
marko2F5G6
The problem persist for me also, i have updated to win11 and reinstalled Fusion but no change. The problem is also there when using Light Gray theme but only on pop up explanations.
Message 11 of 17
andreyjb15
Observer
Observer
I'm also still having the same issue. I'm using light gray so far to avoid the issue. I tried changing the windows 11 themes, contrast and screen configs. Until now nothing solved the issue.
Message 12 of 17
RajkumarIlanchelian
I will point this post to our engineering team to look at. Will post back on any updates.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 13 of 17
lance.carocci
This is a known issue for some users that, unfortunately, we have been unable to reproduce internally. If there is anything particularly notable about any of your system configurations (including docks or USB video adapters), please let us know.
@Radko29 can you please including a recording of this?
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 14 of 17
Radko29
Message 15 of 17
lance.carocci
Thank you. It looks to be affecting the light theme, too, just more difficult to notice.
Lance Carocci
Message 16 of 17
Radko29
If it helps, I can provide remote access to my computer so the problem can be identified.
Message 17 of 17
Radko29
It’s a bit better now. The only issue is that the settings window is still white. Everything else seems to be fine.
