Critical Issue: Fusion 360 Search Fails to Find Existing Files
joshua_sniffen
Message 1 of 38
joshua_sniffen
Hi Autodesk team,
I’ve been a long-time Fusion 360 subscriber with hundreds of designs stored in the cloud across various projects. I’m now encountering a critical issue that is severely impacting my workflow: the search function fails to return files, even when I enter an exact match of a file name that I can see in the data panel.
I understand (although am frustrated by) the inability to search files with underscores between words, but having files just not show up has cost me a hundred hours this year alone...
Details:
  • File is visible in the data panel under the correct project
  • File name includes the word “camera”
  • Search is set to All Data
  • No filters are active
  • I’ve verified spelling and tried both full and partial match queries
  • The file is not archived and was created directly within Fusion
  • Even after renaming the file, waiting, and re-searching, it still doesn’t appear
  • Web-based Fusion Team search yields inconsistent results as well, but it is MUCH more reliable.
SOMETIMES if I manually find the file, and leave it open for at least 15 minutes, it can be searched again. But it is seemingly random if it will show up next time I need it, months later.
This behavior makes it nearly impossible to manage a growing library of designs. I rely heavily on search for navigating my work, and this issue has reached the point of becoming a serious blocker.
System:
  • MacOS 15.3.2
  • Fusion 2601.1.29 arm64 [Native]
Please advise on how this can be resolved.
Thank you for your time.
Replies (37)
Message 21 of 38
MarhallT
I am having the same issue. Has a solution been created yet?
Message 22 of 38
vinayak_dhame
Hi @MarhallT ,
Can you check if you are able to search files using HomeTab.
Link for HomeTab Overview.
If my answer helped, please 'Accept Solution'
Vinayak Dhame
Autodesk Fusion
Message 23 of 38
Calley479
Any hope of this being fixed?   My search has been nearly unusable for years.
Searching for an important document found 2 old copies over 6 months old but not the document I had just edited days ago.  Selected "All Data" says the same...  even selected the folder I know the file is in an it says the same thing.   I don't use any special characters in my file names, just alphanumeric.
Tried on a different computer (use the same account at home and work) but same issue. Tried searching ALL words in the name of the file.  But all searches return only two older versions of the file a I saved as backups over 6 months ago....  but no search returns the correct file.
The internal search within the application is broken and has been for a long time... this must be addressed!
Message 24 of 38
vinayak_dhame
Hello @Calley479 ,
Sorry to hear about the issue you are facing searching for a few files.
We have raised this with our team, to investigate more, I have DM you for getting a few details which will help the team.
Also,
Can you check if you can search files using HomeTab.
Vinayak Dhame
Autodesk Fusion
Message 25 of 38
ranathings
Observer
Observer
I am having this issue as well. I can see the file in the browser but when I search for it nothing shows up. This is a huge problem.
Like honestly just make a list of all my files and I will ctrl+F it...
Message 26 of 38
vinayak_dhame
Hello @ranathings ,
Also,
Vinayak Dhame
Autodesk Fusion
Message 27 of 38
umairABV9U
I have followed this thread, but I am helping a client of mine who still has this issue. We also used the Home Tab Search to find the file but it couldn't find the file. There are no special characters, just a simple string of numbers. I can see the file in the data panel. Name is correct. But when searching for it does not show up. Can anyone help?
Thank you
Message 28 of 38
danS8JRH
This has gotten worse. Searching from the "home" screen does not always find my file. It is getting increasingly frustrating. I've tried to use the old school " " in the search bar to find an exact match but that doesn't help either.
Message 29 of 38
ritesh_khatri
Hi @danS8JRH  and @umairABV9U ,
I'm really sorry to hear that you're still experiencing issues with search. I've sent a direct message to both of you to gather a few more details about the problem.
This will help us investigate and address it more effectively.
Thank you for your patience and cooperation.
Ritesh Khatri
Autodesk Fusion
Message 30 of 38
ab646123
I have the same issue.  The search feature is BROKEN.  Stop collecting random data and test it one of your updates made it in operable.  This is not a user error...  Add me to you list of probably thousands experiencing the same problem.  Please fix.
Message 31 of 38
bigbrad73
This is pretty major problem! Why isn't this fixed already? a simple search function shouldn't be a big deal. I waste all kind of time looking.
Message 32 of 38
CRANDALLPRECISION
this is still an issue. especially if you have subfolders. Waste of time need the easy ability to save to windows so we can easily find our work.
Message 33 of 38
ab646123
It looks like the Fusion Support team has abandoned this issue as I do not see any responses from the in the messages.  Is this being addressed?  Will it be fixed?  Is there a different solution being offered? Be nice is someone from Fusion responded to this post with an update.
Message 34 of 38
collindavis0
Observer
Observer
I am also having this problem. Just crazy for something so basic to not work for so long. Search won't find files buried a few sub-folders down. No special characters or anything. Even searching for the full exact file name with proper case, having the file open for editing, and searching specifically within the correct project folder... it still doesn't find it.
Maybe the move to team hubs did this?
Message 35 of 38
RussPitcher
Observer
Observer
I'm having the same issue here.  It's maddening that such a simple and important feature is so unreliable.
Message 36 of 38
darko.grzinic
Hello all.
Do not worry, we have not forgotten about search behaviors that you are describing and are active working on enhancing search in Fusion.
Very soon new Fusion search experience will be released so keep an eye on What is new documents.
After this new search experience is released, please retest your search and report us if you are still facing issues.
We are confident that these new search experience will be a big step in the right direction for Fusion search.
As for you that my colleagues have sent DMs:
@MarhallT
@Calley479
@ranathings
@danS8JRH
@umairABV9U
Your input on our described behavior if very valuable so please provide requested data if you can.
This way we can be faster and more efficient in providing enhancements and improving your Fusion experience.
Also, sometimes newly introduced capabilities such as HomeTab Overview can help you in your everyday tasks.
Darko Grzinic
Sr. Technology Consultant
EMEA Croatia
Autodesk, Inc.
www.autodesk.com
Message 37 of 38
ran_sips_9p
Yup. Reported this a while ago. Autodesk is aware they're just too busy adding micro transaction features
Message 38 of 38
joshua_sniffen
It's been a year since I opened this thread, and it still happens on a daily basis. For frequently accessed files I even try naming them crazy things that are unique, with no help.
