Corrected unit to addimentional unit cause bug in parameters
sylvain_boyer6TGNB
sylvain_boyer6TGNB
How to reproduce the error:
#1 create user parameter openingRatio, set to 0.7  but leave the default unit in mm
==> create the user parameter with a 0.7mm value
#2 click the user parameter unit and change to NO UNIT
==> the user parameter become (0.7mm)/mm
#3 create a second parameter ILength with unit in mm
#4 try to multiply openingRatio by ILength
Solution for now: delete the units manually in the openingRatio : "(0.7mm)/mm" to become "0.7"
Something in the unit check should be improved. Likely strings are being used as outputs.
sylvain_boyer6TGNB
Errata, the solution is to delete the openingRatio and recreate the user parameter with no units
