copy and rotate sketch
NoHandsNeeded
NoHandsNeeded
hi every one how can i copy this sketch and move it around 90* on the circle?
thanks in advance
No Hanfds
open your sketch you are using in the sidebar rightclick n it copy it and go to the upper part where you can see your file name right click and click paste. then move it to se the copied object click m and you can see the little cricle try to movooe it to rotate it
masa.minohara
Hi @NoHandsNeeded,
Thank you for posting! I have made a screencast that shows how to set pivot to rotate sketch. Please make sure to hit the Done button before rotating the sketch. Hopefully this helps!
Also, this "Support" forum board is dedicated to troubleshooting issues regarding Fusion 360. We have another forum board called "Design, Validate & Document" which is more suitable for this kind of topic 🙂
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
NoHandsNeeded
Hi
I am still confused on how to copy a sketch I don't know why it won't work for me
masa.minohara
Thank you for your response! Could you record a screencast so I can see what is going on?
Masanobu Minohara
patilsm
Please check my attached screen cast for different ways for Copy-Move operation.
Where I shown :- only Move, Copy and Move, Using Circular pattern make copy.
Please let me know If this thing not going to fulfill you requirement.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
