Construction lines
Construction lines
thomasjeppesen
Construction lines
thomasjeppesen
I have designed a simple wooden coaster to be made on a CNC machine i. This means the workpiece needs to be flipped after the first 7 grooves are milled. My plan is to use a 2D pocket operation.
The issue/problem is that the outer grooves cannot be milled using the 2D pocket operation or others.
My assumption is that this might be because the design lines in the sketch are not properly connected? (marked with a red circle)
The file is also attached. Can anyone help?
Thanks in advance,
Thomas J.
jhackney1972
See if this file helps you out.  Model is attached.
John Hackney, Retired
thomasjeppesen
Thank you very much.
-Geomotry closed chain and heights, bottom heights form face.
