Constraint solver / Dimension Bug
leoblue2002
leoblue2002
In my file right now I have a dimension that lies about what its value is. the dimension claims to be the value I set it to, but the entity it constrains is free to move. while it moves the dimension reads the accurate number, but upon stopping the dimension goes back to reading the set value. This dimension references a driven dimension between 2 implicitly projected lines ( the lines that are there when you make a sketch on a face ). I have a video demonstrating the behavior and the file attached.
davebYYPCU
This has been identified as worthy of investigation, previously.
@Phil.E Another driven dimension, referenced in a formula,
inconsistent result, and curiously, also involves angles.
Might help....
sameer_babarNJS6C
@davebYYPCU @leoblue2002
Sorry for the inconvenience caused & Thank you for sharing the file. I can reproduce the issue at our end with file provided by you . Our team will analyse it further more.
We have logged an issue FUS-174776 for it & we are looking for the solution .
Sameer Babar.
Autodesk Fusion Team
