Constraint issues
Constraint issues
bembleandchippy
Observer Observer
Constraint issues
bembleandchippy
Observer
Observer
I am having issues constraining this assembly, They should line up and do when I do it manually but they wont automatically with constraints.
dsouzasujay
Hi @bembleandchippy
You have to make some changes before applying Joints
  1. Delete 'Ground' For Casing
  2. Open 'Casing' in a new tab, Right click on 'Bodies' select 'Create Components From Bodies'
  3. Open 'Assembly Copy', Expand 'Casing' and 'Ground' only the base plate
  4. Delete and redefine sick joints
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
g-andresen
change the orientation REV 31 to CYL 31
günther
bembleandchippy
Observer
Observer
Hi @dsouzasujay
Thanks for your help but unfortunately I cant split up the casing as it is a model of machined surfaces of a cast casing.
I just found a solution of changing one of the rotational joints to a slider joint as there turns out to be a fraction of a decimal offset in the parts.
