Constraint Help
Constraint Help
mouse51180
Message 1 of 9
Constraint Help
mouse51180
Im trying to work on a piece to 3d print that will interlock with itself.  I seem to have everything constrained except for some circles that will be used for some magnets and the vertical pieces of the interlocking parts.  I am not sure how to properly constrain these to make this work.
I am also trying to use the sketch\scale feature on the bottom cutout parts, but they don't seem to be working as expecting and I think it's due to the missing constraints.
Replies (8)
Message 2 of 9
TheCADWhisperer
@mouse51180
I see a lot of missing constraints.  Mostly Midpoint.
Why are these Construction lines showing as under constrained?
Could you be missing Horizontal and/or Vertical constraints?
Click and drag.  What do you observe?
Message 3 of 9
HughesTooling
Easier to draw one half only and not trim the rectangle. To keep parts central I've used midpoint and vertical constraints. (tip, if you start the Horizontal\Vertical constraint, hold the shift key and move the mouse pointer over the midpoint of a line you can pick the midpoint while adding the vertical constraint). I used a parameter (Clearance) to add clearance to the bottom dovetail.
From the sketch just extrude then mirror for the other half. You could use a pattern but Fusion doesn't have a way to automatically join patterned bodies. File's attached.
Mark Hughes
Owner, Hughes Tooling
Message 4 of 9
HughesTooling
Thinking about this a bit more and I've come up with a way using a pattern so you could create this with more than 2 sets of holes and dovetails.
Using parameters create a sketch like this that will stay centred using different settings.
Then an extrude and pattern faces.
Just adjust the count parameter for what you need. File's attached.
Mark Hughes
Message 5 of 9
TheCADWhisperer
@mouse51180
You have been shown the correct technique by @HughesTooling but you should still strive to understand why your sketch is not fully defined.
I can see obvious omissions just from the image without even having the file.
When in doubt, click, drag, observe.
Message 6 of 9
mouse51180
Thank you for both your solutions.  I think your second example is too advanced for my current skillset with Fusion and I am trying to replicate your first drawing.
My original thought was to do half and the mirror the drawing, but I was having issues getting the dove tail pieces to mirror and could only get the circle to mirror.
@TheCADWhisperer The reason my construction lines were constrained is because that is how I found I was able to get the dovetail pieces centered on the circle and still collinear with the top and bottom edges of the piece.
@HughesTooling I am still having issues just trying to reproduce your example.  I'm not sure if I'm sketching this out incorrectly or just in the wrong order.  Here are the three issues I am fighting with trying to find the proper steps.
1) If I make my outer parameter box 19x20 > create a circle on the midpoint of the top edge > remove the midpoint constraint > move the circle down 7mm...I cannot do a horizontal\vertical constraint on the circle as seen in your example.
(view in My Videos)
2) Im curious how you made the dove tails.  I have been creating them outside the parameter and them used the midpoint constraint to attach it to the part.  This seems to be defined at this point, but not I have an over lapping line.  In your sketch you do not appear to have these overlapping lines.
(view in My Videos)
3) My last issue in order to make the interlocking piece... I was going use the sketch scale tool, but when I use that... the top and sides dont seem to adjust out equal distances as I would expect.  The top clearance looks to be a larger distance than the side clearance.
(view in My Videos)
Thank you for the help in assisting me understand how to do the job right.
Message 7 of 9
g-andresen
1. do not select the circle but its center
2. select the line > left-click + hold 2 s > select > delete
3. use the offset tool instead of scaling
(view in My Videos)
günther
Message 8 of 9
TheCADWhisperer
@mouse51180
Turn on your sound...
(view in My Videos)
Message 9 of 9
TheCADWhisperer
@mouse51180
You really should have attached your file.
I think you would have learned more from seeing how one of the experts here would have fixed your file than merely demonstrate the correct way.
When I was teaching, I would often show several incorrect techniques working the students towards a logical solution.
Just showing the solution would have less impact.
