Constraint created by Python API fails while the same one done manually works
aleksei_ovsienko
Message 1 of 1
aleksei_ovsienko
I give you two models. Identical by the looks of it. Exactly the same model with the exactly identical constraints in the end of the timeline. It doesn't even display as failed in the timeline. Yet on one of the the constraint fails silently and if you go to edit it - you can't even get it to compute. It was created by Python API.
However - recreate the same constraint manually, exactly same - and it works.
Can you tell me what is the difference? What am I doing wrong? Should I post this in API forum section? I posted here because nothing I posted so far in API gets any attention. And by all means this is a bug. Two identical constraints shouldn't work differently. My only conclusion is they are somehow not identical and I fail to see how.
I have submitted it as a case through Support as well.
Edit:
OK. I was a little bit daft here. I found the conflict. It was direction toggle on the Plane- Plane constraint. But it is a center plane. Why does it's direction toggle even matters and sets a direction when there are other constraints to do it? Should this be fixed perhaps?
Replies (0)
