Complex Model develops errors when small edits made
jkurtis
Message 1 of 14
jkurtis
Hi- I have designed (and partially built !) a gantry style milling machine. For me (self-taught, non-engineer), it's a pretty complex model with lots of joints and assembled components...
that said- it "computes all" without any errors or warnings (though it takes several minutes to run- yes, I need to remove the unnecessary capture position entries).
When I go to make a simple edit (in this case, to a Y axis limit switch highlighted in red in screenshot), I get a pile of errors (see screenshot) and the relationships between other, unrelated components becomes corrupted (highlighted in blue in screenshot). This happens when I make other small edits to several other components that appear unrelated to this corrupted component...
I append the model files of the original (no errors) model as well as the model after the edit that results in errors...
Any help/advice you could offer would be most appreciated.. I need to make a bunch of edits and have been stopped by this behavior....
thx,
jake
Replies (13)
Message 2 of 14
jkurtis
in case folks were not comfortable with downloading a zip file, I will attach several fusion files in sequential replies....
Message 3 of 14
jkurtis
here is fusion file that has no errors (before edit to limit switch bracket)...
Message 4 of 14
jkurtis
here is fusion file after small edits to limit switch bracket that has errors
Message 5 of 14
TrippyLighting
To reduce the re-compute time, my suggestion would be to assemble all the bricks in a separate design. If you eliminate all of the position capture features in that section of the design stuff is going to go horribly wrong 😉
Message 6 of 14
TrippyLighting
Using individual revolute joints between the energy chain pieces won't produce fluid animation and will also overburden Fusion's joint solver.
Edit: While it doesn't look too bad on my machine, no one doing this professionally would. At least not in the custom manufacturing automation industry I work in.
Way too much work for too little, or no actual benefit.
Message 7 of 14
jkurtis
totally agree- I did it 'cause I thought it looked pretty cool.. I could eliminate the energy chains from the model altogether... but I still can't figure out why small edits to unrelated components cause errors on the Blue Motor mount side plates...
Message 8 of 14
TrippyLighting
I would consider a complete refactor of the design!
Fusion does not have a built-in function for this (and many other things, unfortunately) , so I used the AI assistant to count all of the position capture features in this design. There are staggering, hard-to-believe 710 position capture features in this design. Designs like this should have no position capture features at all!
The design should also have NO pin features at all. Since the introduction of the Ground-to-parent attribute, the pin feature has become legacy functionality.
If you don't do this, it will be very difficult to determine the root cause of the error you are seeing. You might get lucky and eliminate one bug, but moving forward, if you want to make more changes to the design, you'll likely run into other troubles.
Message 9 of 14
TrippyLighting
Here is one approach that might work, though it has limitations and needs rework!
Message 10 of 14
Phil.E
Is there a CAD application that has a refactor feature for reference?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
Message 11 of 14
TrippyLighting
@Phil.E I would not know of one. I think that is one area the AI assistant could be very helpful for!
I've not had a chance to use it much.
Message 12 of 14
Phil.E
Thanks, just checking because it sounds useful.
One thing about this case, I would like to share what I tell my Fusion students who are new to CAD.
If the geometry isn't the thing you're making, don't put it in the file with the thing you're making.
The advice to keep the bricks as a separate assembly, perfect advice. What is it you're making? metal parts for a mill, not  masonry. I would ask my students "what goes in the box with this product, a bunch of bricks and mortar mix?"
This is always the perfect segue to talk about Xref modeling. I prefer a hybrid approach myself, which is where external linked design components shine. That way the external stuff is reference, i.e. not intended for any CNC or injection molding, or sheet metal bending, like the parts I'm designing.
Anyway, just one way to keep the hot side hot and the cool side cool, if you can remember the reference.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 13 of 14
jkurtis
Thx- I am just learning Fusion, so did not realize the compute penalty of all the Capture Positions... I now understand that I should let the joints confine the position of components.. thx
Message 14 of 14
jkurtis
hi trippy… I just wanted to thank you so very much for the huge amount of time and effort you put into answering my question. Your video was really helpful to me. I will take your suggestion, I will export each logical sub assembly, fix the errors that occur during the export. And then reimport the assembly back into a master file. This of course is a hard lesson for me to learn, but I do this as a hobby so that's part of the fun 🙂
I have one quick question, you use the word refactor several times... does that word just mean the process that I described above ?
when I've completed the process, I will report back just to close this thread.
Again, I really wanted to thank you for going so far out of your way to help.
Best, Jake
