Constrained Orbit Camera Failures
mavigogun
Advisor Advisor
mavigogun
The accompanying screencast documents Constrained Orbit dysfunction.    While some of these behaviors were previously observed and reported, others are new.   In summation:
  • Pointer Icon inconsistent, sometimes appearing as Free Orbit Icon when the Constrained Orbit Retical is on screen
  • When 90 to cardinal plane, activating a Constrained Orbit side handle causes the view to flip 90 degrees
  • When activating a Constrained Orbit side handle, the view stays parallel to the initial view plane, instead rotating the view as though looking down on a turn table
  • Within the last described failure, the rotation direction reverses at 180 orbit of the Retical
Constrained Orbit is an essential tool.   You've broken that tool.   Please fix it.
saito.kh
Autodesk Support
Autodesk Support
Hi @mavigogun,
Thank you for reporting this!
Sorry to hear that.  I also thank you for sharing the Screencast!  I've add your reports into the ticket (internal ID: FUS-43146).  I will update in this thread once I have something to share about this issue!
I apologize for any inconveniences this may cause you - we appreciate you bringing this to our attention!
At this time I would try using free orbit while it is investigated.
If you have any questions, please let me know and I'm happy to help!
Thanks.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
mavigogun
@saito.kh, hey, Kanehiko- just checking back to see if this is still on the radar.   Why?   Because I just needed to perform a Constrained Orbit along the problem Axis, and continue to suffer the 90 degree flip.  Any word of status will be appreciated.
