Constraction Planes parallel to XY
I can not define a working plane parallel to XY twisted around the Z axis.
All tests lead to a plane that is completely parallel to XY, that is, the X and Y axes of the working plane are parallel to the X and Y axes and not twisted by a proper angle.
kate.raskauskas
Hi @Anonymous,
Just to clarify, you're seeing something similar to this and want the top square rotated about the z axis, right? Can you explain a little more about what's next in your workflow that needs this rotation?
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
I define the BLUE construction plane and the F360 displays YELLOW. Each way of defining this plane leads to the same wrong end result.
I need to make some hols on BLUE surface.
I think that this stupid  error in F360 is easy to repair in program
thank you anonymous programmer for a silent fix, now everything works fine
all is OK
