Consistent Crash from (Insert) Derive with Shared Parameters Part
knifacat
knifacat
Hi folks!
Running into this consistent crash with (Insert) Derive with this particular component.
The component in question is a blank part with parameters only, which I've used to share global parameters for a project between several other parts. I'm not sure if this is an entirely reasonable workflow but it was working up until now!
However, out of nowhere this shared parameters part now refuses to be derived onto any other new parts and causes Fusion 360 to crash. Both ways cause the crash --- Insert -> Derive and Create -> Insert Derive.
The cursed part can be found here.
Screencast of crash.
Please help! I'm not even sure where to begin.
There are four other parts using this shared part, and they all refresh, etc. with any changes without crashing.
Cheers,
Dan
jodom4
Hey knifacat,
Is what you're experiencing similar to what's happening in this thread? It might be helpful to chime in there:
https://forums.autodesk.com/t5/fusion-360-support/f360-crashes-whenever-try-to-update-derived-compon...
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
knifacat
Thanks! It does sound a bit similar. I've shared my issues in there now.
