Conic Curve Rho Value and User Parameters
evan.rust
evan.rust
I'm unable to use updates to a user parameter to control the rho value of a conic curve. When I create or manually modify the conic curve I am able to type the user parameter name to set the rho value, but any changes to that user parameter in the Parameters window do not update the curve.
Is there a way to use parameters to control the rho value?
jeff_strater
this is not yet supported.  See:  bug-conic-curve-sketch-parametric-modeling
Jeff Strater
Engineering Director
tglynnT3TZH
Observer
Observer
Any update on this?  I'm designing a replacement waterpump for a historic engine. There are 6 mounting lugs to the block which I'm modelling in Conic Curves. The ability to set a Rho value and update the curves dynamically would be helpful - but not the end-of-the-world 😁
danielwdunn
Observer
Observer
I would also like this bug fixed or feature added to parameterize the Rho value for conic curves.
Hearing_
I am currently working on a design with conical curve profiles. It would save me a ton of time if this was fixed!
danielwdunn
Observer
Observer
Is this on any current product roadmap for implementation?
jason.pettiaux
Community Visitor
Community Visitor
For those wondering, define you parameter unitless and it works
