Message 1 of 10
02:21 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have drawn a little box for wafers (see attached file). The design is parametric, and one of the parameters is called waferwidth. While drawing I had it set to 166 mm, everything rendered fine. I then subsequently set it to 83 mm to check if smaller sizes worked. Nothing exploded, so I set it back to 166 mm, only for the design to fail with the message "Warning: Sketch1 Compute Failed: Failed to solve. Please try revising dimensions or constraints."
Unfortunately this is all the detail I get, no mention of which constraint failed. This is especially annoying since I did not change anything in the design that previously worked. Help?
