Compression Mould Design of Complex Generatively Designed Body
stefan_radovich
stefan_radovich
Hello
The end goal is I want to make a forged carbon (Compression moulded) part similar to the attached complex geometry part.
Search "easy composites forged carbon youtube" to have an idea of what I'm talking about.
I need to design a multi part mould to produce this. Simply combine cutting from a larger box body doesn't work as I need a "piston" piece to be able to do this.
I can't seem to be able to extrude from a mid-plane projection or sweep along a path to do a swept cut.
Any ideas how a compression mould for this could be made?
(This isn't the end goal piece but a simplified version with a more obvious mould split direction so I can learn how to do it, i.e. this part is "flatter")
stefan_radovich
To try and explain it better the end goal mould split planes would need to be a complex 3d shape according to the draft angle, i.e. not a simple single plane slice of the design. Complicated, but should be possible.
henderh
Hi @stefan_radovich,
This post reminds me of a similar topic that @Ben-Weiss provided a solution for, attaching a step-by-step video:
Hope this helps,
Hugh Henderson
QA Engineer (Fusion Simulation)
