Components hanging vertically
spudym
Message 1 of 9
spudym
I might be asking for the impossible here.
I would like to animate a set of weighing scales.
I have a joint for the arm and joints on both ends of the link.
When the arm is tilted I would like the bowl to stay vertical, is this even possible.
Replies (8)
Message 2 of 9
davebYYPCU
You can do that with Assemble > Motion Link.
Select the the 2 joints, enter a ratio value 1 to -1 or 360 to -360
Set the minus sign to the respective joint as required.
3 joints - 2 Motion Links.
Might help....
Message 3 of 9
spudym
Awesome, Thank you so much.
Message 4 of 9
spudym
Thank you for your help, could I impose and ask if you have any thoughts on how to make it work in the animation space. I can get the arm and bowls to move but yet again the bowls joints are locked. even though they behave correctly in modeling space.
Thanks Matt
Message 5 of 9
davebYYPCU
Select the joints.
Along the timeline - set the sweep angle - for each joint, timing will be identical, values used in the Design space will have to be converted.
Might help....
Message 6 of 9
spudym
Thank you for the reply but unfortunately cannot work it out.
Matt
Message 7 of 9
davebYYPCU
Will need your file to check it's build.
Message 8 of 9
spudym
Here it is,very embarrassing but.   https://a360.co/3HxgMk2
Message 9 of 9
davebYYPCU
Do you mean -
Animate Model from the Joint right click menu, (works)
Motion Study from the Assembly Menu, (use + / - 35 degrees)
or the Animation Workspace? (For movie export)
