Component Mirror command shows in timeline but no mirrored component is created
unicorn9004
Observer Observer
unicorn9004
Observer
Observer
Hi everyone,
I am currently working on a robot figure project and having a strange issue with the Mirror tool.
I can mirror bodies without any issues, but mirroring components is not working. When I try to mirror a component:
  1. The mirror dialog opens correctly.
  2. I select the 'Pattern Type' as components.
  3. I select the component and the mirror plane, then click OK.
  4. The Mirror command appears in the timeline, but no mirrored component is generated in the Browser or the Canvas.
To iterate on my design, I used "Save Copy As" on a specific component (the head) from my original assembly to create a new standalone file. I am now working within this new file. Could this workflow be causing the issue?
Any help would be greatly appreciated. Thank you!
g-andresen
please share the f3d file for reply
File > export > save as f3d on local drive > attach to post
günther
unicorn9004
Observer
Observer
I atteched f3d file
TheCADWhisperer
@unicorn9004
If this were my design:
1. Each and every sketch would be fully defined.
2. Ctrl b would not report any unresolved issues.
3. I would probably not have any Move commands or at least not multiple Move commands for the same move.
4. I would have one Grounded Component.
rosie_lucas1
Hello @unicorn9004,
I just wanted to check in and see if the information provided by @TheCADWhisperer helped you and answered your question?
If yes, could you please click on the "Accept Solution" button at the bottom of the post that helped solve your issue. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
Rosie | Community Manager
