Component Gets Rotated But Not All Sub-Components Rotate With It
- Mute
- Permalink
- Report
I have a Component that has a bunch of sub-Components. It all looks fine. But I needed to make a substitution for one of the Sub-Components, a BoltAndWasher.
The original BoltAndWasher was added to the overall Component as a Cut-PasteNEW, and I really should have made it as a simple Cut-Paste so that it would be linked back to the original, "master", BoltAndWasher. So I located the place in the timeline where that BoltAndWasher existed, set the History Marker just after it, and DELETED it from the timeline. Doing that Delete caused an EXEPECTED error for a subsequent Circular Pattern that replicates the BoltAndWasher into the rest of the bolt holes along the bright band at the top of the component. I then did a Copy-Paste from the master BoltAndWasher into the same location in the timeline and did a Joint operation to position on the main Component in the same location where the prior (Cut-PasteNEW) one had been, namely that upper left bolt hole. I then edited the Circular Pattern feature (which no no longer had a Component to do the pattern with) and told it to use the newly added and positioned (Cut-Pasted) BoltAndWasher. And, so far, it looked good, just like it had before I replaced the Cut-PasteNEW version of the BoltAndWasher with the Cut-Pasted BoltAndWasher. It still looked just like the above picture.
I then let the timeline run to the end of the main component. A lot further down the timeline for the main Component a Move-Rotate is done that rotates the entire Component 120 degrees around its vertical axis. That's fine. It in fact NEEDS to have that rotation in order to properly place it in the design. And PRIOR to my BoltAndWasher edit to the component, replacing the Cut-PasteNEW with the Cut-Paste BoltAndWasher, it all went fine.
BUT now, with that edit, the rotation doesn't work right:rotate 1.jpg
The main component rotated properly. The new Copy-Pasted BoltAndWasher, which was Jointed into position on the main component got correctly rotated. But all the (copies of that) BoltAndWasher that were created by the Circular Pattern operation did not move at all.
All of those extra BoltAndWashers that are created by the CirculrPattern operation are indeed where I expect them to be in the Browser hierarchy, namely as sub-components of the BoltsAndWasher sub-component which is within the One-Third Section component.rotate 2.jpg
It's that One-Third Section Component that gets Move-Rotated, so why aren't all the sub-components rotating with it?
WHY IS THIS HAPPENING? I AM QUITE BAFFLED.
Does anyone have any clue as to what I might have done wrong?
