Component dissappears when sketch edit requested
micromelt01
Message 1 of 16
micromelt01
Hi. I have created a simple component which I activate and isolate. It has one sketch and a subsequent extrude.
When I right click on the visible sketch and click on Edit Sketch the whole component dissappears and only returns when I close the edit sketch box. What am I doing wrong. Thanks
Replies (15)
Message 2 of 16
TheCADWhisperer
@micromelt01 wrote:
... It has one sketch and a subsequent extrude.
Isn't the Extrude a child of the Sketch?
Child can't exist before parent.
I feel like I must be missing something as you already have an extensive Timeline.
File>Export and then Attach your *.f3d file here.
Edit: Can you reproduce this behavior in a new file with only one sketch and one feature?
Message 3 of 16
micromelt01
Thanks for the quick response. I am a novice here. More used to SW.
My workflow was:
  1. Create new component and name it
  2. Draw sketch and dimension
  3. Extrude sketch.
  4. Join component to main assembly (hence the timeline)
I attach file as requested.
thanks again.
Message 4 of 16
wmhazzard
Like @TheCADWhisperer says, that is normal behavior. If you edit a sketch you in effect roll the timeline back to the sketch which is before the creation of the body so the body disappears.
Message 5 of 16
micromelt01
So how do you edit the sketch if you can't see it
Message 6 of 16
TheCADWhisperer
Why can't you see your sketch?
This is the same as in SolidWorks.  (I have been a CSWP for more than 10 yrs.)
Message 7 of 16
micromelt01
I am obviously missing something here. I can see the sketch as part of the component but when I click on 'Edit Sketch' it all dissappears as in original screenshot video
Message 8 of 16
jeff_strater
@micromelt01 - I tried editing the sketch in the simpler model you shared.  It seemed to work OK for me.  Do you see behavior different than this on your simple model?  The video you shared at the start of the thread is much more complex than this design.
Jeff Strater
Engineering Director
Message 9 of 16
micromelt01
Hi Jeff,
Your clip shows what I expected to see. When I activate and isolate the component within my assembly I see a different result. You can see this in the clip I have added in my first request to the forum. I can't see what I am doing wrong.
thanks
Message 10 of 16
HughesTooling
What happens if you double click the body, right click and activate then edit the sketch from the timeline? Also have you run a Compute All Ctrl+B just in case there are any errors that are not showing up.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 11 of 16
HughesTooling
Your timeline looks odd in the clip, it looks like all items are greyed out before and after the timeline marker. Also do you have Hide all inactive features enabled?
Mark
Mark Hughes
Message 12 of 16
HughesTooling
One more question, was the component created in the design or inserted then had the link broken? If it was inserted have you inserted the same design more than once?
Mark
Mark Hughes
Message 13 of 16
jeff_strater
@micromelt01 - thanks.  Probably the best course at this point is for you to share the original design here, and record another screencast showing the workflow of just these steps:
  1. open the design
  2. edit the sketch in question
If there are other steps you do in the process, such as activating a component, include those as well.  It is certainly possible that there is a bug here that is preventing the sketch from being visible, but I haven't yet been able to reproduce them on my side...
Jeff Strater
Message 14 of 16
micromelt01
Thanks Mark,
The component was created from within the design and when I try to edit the sketch the timeline is not greyed out as in the screenshot but the whole component still disappears.
regards,
David
Message 15 of 16
micromelt01
Hi Jeff,
How do I attach the files so as they are for your eyes only.
regards,
David
Message 16 of 16
jeff_strater
thanks, @micromelt01 - the easiest way is to share a public link to the design (see:  How-to-share-a-Fusion-360-design , then copy that link and send it to me in a Private Message on this forum (hover over my name and choose "Send Private Message"):
Then, just paste the public link in that PM and I should be able to download the design from there.  Thanks for your patience.  This seems to be a strange one...
Jeff Strater
