Component assembly
Component assembly
john
Message 1 of 8
Component assembly
john
Hi, i'm trying to find the correct/best way to position a number of components - tried joints but seems like it need 2 on the same component body which does work.
I want to have the roof slats sitting on the curved sidewall at the top end of each slat and the other end on top of the lower slat. - sorry difficult to describe. its for roof slats on a birdbox.
I created the powerpoint picture to show what the end vire would look like and the red circles showing the contact points.
Any ideas most welcome
Replies (7)
Message 2 of 8
TheCADWhisperer
@john
Message 3 of 8
jhackney1972
Attached is a video showing my method of adding your singles.  I created a simple assembly to demonstrate the process on and it is attached for your inspection.
John Hackney, Retired
Message 4 of 8
john
Thanks - file attached
Message 5 of 8
TheCADWhisperer
@john
I would do this design very differently.
Using arc in place of the spline would make manufacturability easier and as a bonus you could Circular Pattern all of the shingles except for the first one.
Let me know if you would like to investigate alternative modeling techniques.
Message 6 of 8
TheCADWhisperer
Since this assembly is not a motion mechanism - the components can be modeled from a single sketch in body position and Grounded.
Step through the Timeline.
Message 7 of 8
john
Wow thanks so much for this and your time - very helpful. I'm learning new stuff every day.
Message 8 of 8
john
Thankyou, this has certainly given me a different way of approaching the design. Appreciate you time on this.
