Combining two bodies doesn't combine
nathanautodeskNKHEC
nathanautodeskNKHEC
I've been using fusion 360 for a couple of weeks, so forgive me if I'm missing something obvious.
I have two bodies that I'm trying to join. I've used the combine object to join 3 other sets of similar bodies with no issues, however a fourth set of 2 bodies just refuses to combine. To demonstrate I've made a quick screencast.
Any ideas?
Thanks.
jeff_strater
@nathanautodeskNKHEC, are you certain that the two bodies overlap or at least touch?  This is required for Combine to successfully combine two bodies.  If you share your design here, we'll take a quick look.
Jeff Strater
Engineering Director
nathanautodeskNKHEC
Yes they definitely touch. The parts that aren't combining are copies of other parts that did combine fine.
I'm not sure how to share my design.
Thanks.
nathanautodeskNKHEC
I decided to try moving the two bodies 0.01mm closer together, and they combine successfully now.
It makes no sense, given that it's a copy of a pair of bodies that combined just fine, but I will consider the issue closed. Thanks for your help!
sebastien_lec
Hello friend of the past,  i was getting the same problem between a thickened surface and a sweep body.
After moving one of them of 0.01mm it now combine. Thank for the tips.
