Combine multiple sketches into one
Is it possible to merge two sketches into one.  If so, how.
jhackney1972
It is not a true Merge but the process in the Screencast will accomplish what you want.  I did it in the same file sketch but you can also do it between sketches in separate files.  This is the closest you probably will come to a Merge.
John Hackney, Retired
jeff_strater
if your goal is to produce a sketch that is a composite of more than one sketch, you can Project the contents of each sketch into an existing or a new sketch.  Project will keep it associative with the original sketches.  This only really works, though, for sketches on planes that are at least coplanar with each other.
Jeff Strater
Engineering Director
g-andresen
You can also combine several in one.
Screencast
günther
