combine function fails when using join operation
Message 1 of 1
hello, i have been working on this model for a decent amount of time and have been consistently running into an issue where the Join function in Combine fails. some background would be that I am making this as a part for a gocart, and I would like to import this into Autodesk CFD so I can run an analysis on its drag. but, whenever I try to import the model, it consistently fails to import the entire part, which is why I have been trying to combine all the individual parts into one. the errors that I have been getting include: "system inconsistency processing surface tangency", and "There was a problem combining Geometry together. If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident)." if anyone might be able to shed some light on this I would greatly appreciate it.
Thank you
Replies (0)
