Colorblind Accommodations for Students ADA compliance
hannah_bright
hannah_bright
I have a student that is colorblind (red-green) and is facing issues with components being displayed with similar colors. He can't tell the difference between them. Is there a setting that helps with colorblind filters?
If you press "Inspect" and then click "Display Component Colors" then Fusion auto-assigns colors to the components. Is there a way to accommodate colorblindness for these specific components?
jhackney1972
In the video I show you a couple of options, from assigning your own Appearances and adding them to My Appearances so they will be available in every model.  I also show you how to "Toggle" the Automatic Display Colors so you can find colors to suit.
(view in My Videos)
John Hackney, Retired
hannah_bright
That was a helpful video! Thank you! Maybe Fusion will allow an option under "Cycle Component Colors" to let users assign available component colors from a dropdown list of options! Either way, this is helpful in the meantime!
