- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, I did a test piece to dial in some CAM operations for Fusion 360 before I build a bookshelf for a client. I'm trying to create a 2D pocket in plywood that will be wide enough to accept my shelves. The material thickness is .73" and I created a pocket that was .745" wide, allowing .015" of slop for the dado joint. I ran my operations and when I measure the pocket width it is .72", so .025" under what I was intending. I don't think this is an issue with my machine, or the CNC bit (1/4" compression bit), because my overall profile pass created a part that was within a thousandth or 2 of the intended 12" x 8" piece. I have checked all my settings in the 2D pocket menu and can't find anything that would account for the discrepancy in width--I unchecked "material to leave" for example. I will attach my file. If anyone has any insights they would be much appreciated!
