Close button missing render environment.
aneedles91
Observer Observer
Message 1 of 21
aneedles91
Observer
Observer
This only happens at certain times. I have to force close fusion because I can't get the went windows to go away.
Could it be a high dpi issue?
Replies (20)
Message 2 of 21
paul.clauss
Hi @aneedles91
Thanks for posting! Which dialog exactly is missing the "close" button (when starting a render, viewing a rendering in the gallery...)? If you can share a screenshot it may help us reproduce the problem.
This could be a UI issue triggered by high DPI - does it persist if you reduce the display resolution?
We appreciate you reaching out about this and look forward to learning more!
Paul Clauss
Product Support Specialist
Message 3 of 21
sni9er
had the same just happen to me also even if you delete the renders there isn't anything to close it
Message 4 of 21
carl_the_archer
Also happened to me a few times and again today
Message 5 of 21
zaaephod
I had this happen a couple times today as well. The first time, the close button was just not there, so I killed the process, and started over. The second time, I just left the process run, and after a while (less than 15 mins), while I was working in Coreldraw. When I came back, the button had appeared. When it happens, it seems the render window is modal, and I'm unable to interact with any other controls in F360, aside from those in the render window. I get the vibe that this is somehow due to F360 contacting remote servers for rendering, even though I'm only rendering locally.
i7-8700K @ 4.5ghz, 32gb ram, Geforce GTX 1080Ti FTW3 11gb, Windows 10 Pro
Message 6 of 21
echojjj
Message 7 of 21
HWiese1980
I did have the same issue. Now there is a "Close" button, but I cannot click it. Nothing happens. How is this still an issue? The initial post is half a year old!
Message 8 of 21
Same issue...
Has there been a response by the support staff ever since all those people said it happened to them, too and pictures have been posted?
I can't even save my project because I am focus locked to that window and I do have some unsaved progess I would hate to lose.
Message 9 of 21
TorqueConverted
I can confirm this is still happening.  Fusion 360, using Windows 10.  The "Close" button disappears on the Rendering Gallery window, locking focus to that window.  I have lost data multiple times due to my file being unsaved, as Fusion 360 must be forced closed when this occurs.  As an experiment, I left Fusion 360 alone and although it took on the order of 3 to 5 minutes, the Close button returned.  It seems like there is some kind of very lengthy loop that is taking forever to run before the Close button reappears on the Rendering Gallery, holding Fusion 360 hostage until it reappears.
Message 10 of 21
jonja20
Observer
Observer
I have the same issue.
Message 11 of 21
chris
Same thing happening to me.
I cannot close the render view window, can't get back to design view, can't close fusion. Only option seems like its CTRL ALT Delete and loose my current progress.
Message 12 of 21
Same problem here. I cannot exit the render mode. Then I deleted the image, but still I cannot leave the render mode. I fear I can only close the program and must hope that I saved my last version before rendering
Message 13 of 21
Same problem a couple of times. Cannot leave the render mode. Sometimes it takes up to 10 minutes before it shows again.
Message 14 of 21
royalcompsci
I've been having this issue for years now.
I have been lucky enough that right-clicking on 360 in the task bar and choosing the close button on the window preview brings up the dialog to save (which I do) and then I see the upload message, the save dialog closes and I'm left with the same unresponsive render gallery window but at least I can murder the 360 task and bring it up again.
Alternately, I have gotten the "close" button back by switching tasks but, as others have reported, the button does nothing and the program remains unresponsive.
Message 15 of 21
royalcompsci
I notice there's been no further input from Autodesk on this issue... for years...
Anyone have any ideas?
Message 16 of 21
TorqueConverted
I just tried to file a bug report and reference this forum thread, but was not able to file the bug report.  Anyone who can should file a quick bug report with the URL to this thread.  Maybe they will finally see and fix this bug then.
Message 17 of 21
allsportsystems
I am also having this issue. Multiple times a day this happens. No way to save work for me.
Message 18 of 21
contactA3JFZ
Observer
Observer
This has been an issue for at least 3 years now. Is there any chance it could be fixed?
SolidWorks is looking really appealing.
Message 19 of 21
Danielism
Observer
Observer
Still an issue, happens regularly and is super frustrating.
Message 20 of 21
WonderEmp
Observer
Observer
Just happened to me. Over four years this bug has been around?
